aosu T2 Ultra Technical Specifications and Features
aosu T2 Ultra solar PTZ camera mounted near an exterior wall corner at night
Technical specifications, feature details, and installation guidance for the aosu T2 Ultra 4K solar PTZ camera.
The aosu T2 Ultra is an 8MP solar PTZ camera that records 3840 x 2160 video at 15 fps. It combines TrueColor Night Vision and Covert Full-Color Mode with PIR and dual radar detection, a 9,200 mAh battery, and standalone or aosuBase storage.
The camera is designed for outdoor areas such as driveways, yards, entry routes, and garage approaches where one adjustable camera position can cover a defined area.
Imaging and coverage Night vision and detection Power and environment Connection, storage, and recording
  • 8MP PTZ camera
  • 3840 x 2160 resolution at 15 fps
  • 110° x 93° x 50° listed PTZ viewing angle
  • 6x digital zoom
  • Recommended installation height: 2.0–3.0 m
  • TrueColor Night Vision and Covert Full-Color Mode
  • Listed night-vision distance: 8 m
  • 10 m PIR detection with dual 10 m radar detection
  • 60 GHz mmWave radar; maximum range 10 m
  • Seven motion-sensitivity levels
  • 9,200 mAh battery
  • 3 W solar panel with integrated or separate placement
  • USB-C charging at 5 V / 1 A or 2 A
  • IP65 weather rating
  • Operating temperature: -10°C to 50°C; battery charging above -10°C
  • 2.4 GHz Wi-Fi plus Bluetooth
  • LAN auto-discovery or Bluetooth pairing
  • Standalone: microSD and optional cloud storage
  • aosuBase bundle: built-in 32 GB eMMC plus external 2.5-inch HDD/SSD support
  • Smart Recording: 60 s; Power Saving Mode: 20 s
  • ONVIF, RTSP, and NAS: not supported
Key Features
The T2 Ultra's camera, detection, and storage functions are designed to work as one outdoor monitoring system. The following features have the greatest effect on recorded detail, nighttime operation, alert behavior, and footage retention.
TrueColor and Covert full-color modes 4K PTZ imaging PIR and radar detection Standalone and aosuBase storage
  • TrueColor Night Vision uses light to provide vivid full-color footage in complete darkness
  • TrueColor Night Vision balances color richness and video smoothness for clearer nighttime viewing
  • Covert Full-Color Mode records in full color without turning on a spotlight, helping avoid the shadowy edges that spotlight illumination can create; video smoothness may be slightly reduced
  • 4K resolution provides an 8MP image for live viewing and recorded events
  • PTZ movement allows the viewing direction to change from one mounting point
  • 6x digital zoom supports closer review of activity within the covered area
  • PIR detection is combined with dual 60 GHz mmWave radar
  • Event types include patrol, loitering, human, vehicle, animal, and area intrusion
  • Seven sensitivity levels allow detection to be adjusted for the installation
  • Standalone installations support microSD and optional cloud storage
  • aosuBase bundles include 32 GB of built-in eMMC storage
  • An external 2.5-inch HDD or SSD can be added to the aosuBase configuration
storage options for aosu T2 ultra
Storage options depend on the configuration: standalone cameras use microSD storage and can use optional cloud storage, while aosuBase bundles add built-in eMMC and external HDD or SSD support.
aosu t2 Ultra TrueColor night vision sample
TrueColor Night Vision uses light to provide vivid full-color footage in complete darkness while balancing color richness and video smoothness.
aosu T2 Ultra Covert Full-Color mode sample
Covert Full-Color Mode keeps footage in full color without turning on a spotlight and helps avoid the shadowy edges that spotlight illumination can create; video smoothness may be slightly reduced.
Compare the T2 Ultra with the T2 Pro
Usage and Installation Considerations
Camera placement determines how effectively the PTZ system, detection sensors, solar panel, and wireless connection operate together. Review the live view and test normal activity at the site before completing the installation.
Mounting position Solar-panel placement Detection setup Connection and audio
  • Install the camera 2.0–3.0 m above the ground
  • Keep the main approach route within the listed 10 m detection range
  • Check the full PTZ movement for walls, eaves, fences, trees, and other obstructions
  • Attach the panel to the camera when the camera position receives suitable sunlight
  • Use separate placement when the best camera angle and sunlight direction differ
  • Plan the separate panel position within the listed 3 meter cable length
  • Select the event types needed for the monitored area
  • Adjust one sensitivity level at a time
  • Test people, vehicles, animals, and ordinary background movement at the installed location
  • The listed 240 m Wi-Fi distance applies to an open area
  • Walls, trees, landscaping, and local interference reduce usable wireless range
  • Two-way audio has a listed effective distance of 6 m
  • Audio recording can be disabled, and a voice-changing function is available
samples of attached vs detached solar panel installs for aosu T2 UltraThe 3 W solar panel can be attached to the camera or mounted separately when the camera position and the best sunlight location differ. Separate placement uses the listed 3 meter cable.
How to reduce false motion alerts
View the aosu T2 Ultra product page
Summary
The aosu T2 Ultra combines 4K PTZ video, TrueColor Night Vision, Covert Full-Color Mode, PIR and dual radar detection, solar power, and multiple storage configurations in one outdoor camera system.
Its installation works best when the main activity route stays within the detection and night-vision ranges, the PTZ view remains clear of nearby obstructions, the solar panel receives suitable light, and the 2.4 GHz connection is stable at the mounting point.
Save 20%
32GB internal local Storage, up to 1TB丨4K TrueColor Night Vision丨360° PTZ, Cross Camera Event Tracking丨Triple Detection, Smarter Alerts丨Solar + 9200mAh Battery Powered
FAQs About T2 Ultra Specifications and Features
What resolution does the aosu T2 Ultra record?
The T2 Ultra uses an 8MP PTZ camera and records at 3840 x 2160 resolution and 15 fps.
What is the difference between TrueColor Night Vision and Covert Full-Color Mode?
TrueColor Night Vision turns on the light and usually captures higher clarity in the center of the image. Covert Full-Color Mode records in color without turning on a spotlight and helps avoid the shadowy edges that spotlight illumination can create, although video smoothness may be slightly reduced.
What is the T2 Ultra motion-detection range?
The T2 Ultra lists 10 m PIR detection with dual 10 m radar detection and 60 GHz mmWave radar.
What storage options does the aosu T2 Ultra have?
A standalone camera supports microSD storage and optional cloud storage. aosuBase bundles add built-in 32 GB eMMC storage and support for an external 2.5-inch HDD or SSD.
Does the aosu T2 Ultra support ONVIF, RTSP, or NAS?
No. ONVIF, RTSP, and NAS are not supported.
