How to Mount a Security Camera Without a Drill
When to Use a No-Drill Installation
Most outdoor security cameras come with hardware designed for drilling mounts into place, but there are some common situations where no-drill methods make sense:
  • You are renting
  • Your HOA doesn't allow drilling
  • Your home has delicate siding
  • Temporary setups where you want to reposition later
  • You want to avoid power tools
No-drill options are generally easier and more flexible, but are usually less stable than drilled installations. It's also important to remember no-drill doesn't necessarily mean no-damage.
Choose Your Mounting Method
The best no-drill option depends on your situation, surface, and setup. Here are the most common options and how to choose:
Clamp or railing mounts
  • Where: fences, poles, balcony railings
  • Pros: easy to adjust and reposition, does little to no damage
  • Cons: installation locations are quite limited and may not be in ideal positions
an example of a mount that clamps onto railing and does not require drilling
Gutter mounts
  • Where: sturdy and accessible gutters
  • Pros: quite secure and easy to reposition, does little to no damage
  • Cons: limited placement options
an example of a mount that clips to the gutter and does not require drilling
Vinyl siding clips
  • Where: vinyl siding only
  • Pros: very easy to install and many placement options
  • Cons: limited weight capacity, generally least stable
an example of a vinyl siding mount that does not require drilling
Adhesive mounts
  • Where: painted walls, metal, glass, sealed wood, polished concrete
  • Pros: clean look, no hardware needed, many placement options
  • Cons: long prep time, usually does damage or leaves residue if removed
an example of an adhesive camera mount that does not require drilling
Summary: Clamps and gutter mounts are secure and no-damage, while adhesive mounts can offer more placement options with more potential headache.
Compatibility note: Most no-drill mounts are universal, so you may need to adapt your camera or reuse its original mount to make it fit.
How to Install Each Type
Adhesive Mount
  • Clean the surface thoroughly with isopropyl alcohol
  • Let the surface dry
  • Press the mount with the adhesive firmly onto the surface for 30–60 seconds
  • Allow adhesive to cure (typically 12–24 hours) before attaching the camera
⚠️ Skipping surface prep or cure time is the most common cause of failure.
Gutter or Clamp Mount
  • Position the mount on the gutter, railing, or pole
  • Tighten clamps securely until stable
  • Check that the mount does not shift or wobble
Vinyl Siding Clip
  • Slide the clip into the siding seam
  • Ensure it locks firmly into place
  • Check that it sits level and does not move
Note: These methods vary by mount—check your product manual for compatibility and detailed instructions.
Final Setup
Once the mount is secure:
  • Attach the camera to the mount
  • Adjust the viewing angle
  • Lock it into position
Final checks:
  • Confirm the mount is stable
  • Check camera positioning in your app
  • Make small adjustments as needed
  • Choosing a mount not suited for your surface → likely to fail
  • Exceeding the weight limit of mount → potential damage to home and camera
  • Mounting in areas with high wind → likely to loosen or fall
  • Skipping surface prep → weak adhesive bond
  • Installing before adhesive has fully cured → mount failure
No-drill installation is a flexible alternative when drilling isn’t possible. Clip and clamp mounts can even allow for repositioning while avoiding damage to your home.
By choosing the right mounting method and following proper setup steps, you can achieve a secure installation that performs reliably over time.
Is it possible to put up an outdoor security camera without drilling holes?
There are several options for installing a security camera outdoors without drilling holes. Some of the most common options include rail clamp mounts, gutter mounts, vinyl siding clips, and adhesive mounts. Each of these are viable options under the right circumstances.
Do I need power tools to install an outdoor security camera?
No-drill install methods such as clamps, clips, and adhesives can all provide easy mounting alternatives that do not require power tools. When done correctly, these methods can provide a stable, long-lasting installation.
Can I install an outdoor security camera if I am renting?
It’s important to check local laws and regulations as well as your rental agreement to confirm that there are no restrictions on security cameras. If you are worried only about rules against drilling holes on the property, there are several no-drill options that can provide a stable installation while remaining easy to take down without damage to the property, such as rail clamps and gutter mounts.
How to Mount a Security Camera on Concrete
