The aosu T2 Ultra is an 8MP solar PTZ camera that records 3840 x 2160 video at 15 fps. It combines TrueColor Night Vision and Covert Full-Color Mode with PIR and dual radar detection, a 9,200 mAh battery, and standalone or hub-based storage configurations.
The camera is designed for outdoor areas such as driveways, yards, entry routes, and garage approaches where one adjustable camera position can cover a defined area.
Specification scope
T2 Ultra is sold in standalone and hub-based configurations. Camera hardware, hub model, regional package and firmware can affect available functions. This page does not yet identify all applicable revisions. Where current sources disagree, confirm the exact model before buying accessories or relying on a compatibility claim.
Technical Specifications
| Imaging and coverage | Night vision and detection | Power and environment | Connection, storage, and recording |
Key Features
The T2 Ultra's camera, detection, and storage functions are designed to work as one outdoor monitoring system. The following features have the greatest effect on recorded detail, nighttime operation, alert behavior, and footage retention.
| TrueColor and Covert full-color modes | 4K PTZ imaging | PIR and radar detection | Storage Depends on the Configuration |
Camera storage, aosuBase 2.0 and aosuCortex are different configurations. Check the exact hub model and its storage instructions before buying expansion media.
TrueColor Night Vision uses light to provide vivid full-color footage in complete darkness while balancing color richness and video smoothness.
TrueColor Covert uses very dim camera lighting rather than the bright spotlight. Available light and exposure affect moving detail; color footage does not guarantee a sharp moving subject.
Compare the T2 Ultra with the T2 Pro
Usage and Installation Considerations
Camera placement determines how effectively the PTZ system, detection sensors, solar panel, and wireless connection operate together. Review the live view and test normal activity at the site before completing the installation.
| Mounting position | Solar-panel placement | Detection setup | Connection and audio |
The 3 W solar panel can be attached to the camera or mounted separately when the camera position and the best sunlight location differ. Separate placement uses the listed 3 meter cable.
How to reduce false motion alerts
View the aosu T2 Ultra product page
Summary
The aosu T2 Ultra combines 4K PTZ video, TrueColor Night Vision, Covert Full-Color Mode, PIR and dual radar detection, solar power, and multiple storage configurations in one outdoor camera system.
Test detection and recorded detail separately along the required route. Keep the PTZ view clear of nearby obstructions, provide suitable sunlight for the solar panel, and check the 2.4 GHz connection at the mounting point.
Compare T2 Ultra with aosuBase 2.0 and T2 Ultra with aosuCortex. Confirm the included hub and compatible storage media before ordering.
SolarCam T2 Ultra
Check the selected hub, camera count, storage media and package contents. Product image is illustrative; included items vary by configuration.
FAQs About T2 Ultra Specifications and Features
What resolution does the aosu T2 Ultra record?
The T2 Ultra uses an 8MP PTZ camera and records at 3840 x 2160 resolution and 15 fps.
What is the difference between TrueColor Night Vision and Covert Full-Color Mode?
TrueColor with Spotlight adds brighter visible illumination. TrueColor Covert uses very dim camera lighting and benefits from available ambient light. In darker scenes, moving subjects may blur even when the background appears clear. See the T2 Ultra Covert and Spotlight explanation.
What is the T2 Ultra motion-detection range?
Current aosu pages list approximately 10 m or 35 ft, without enough detail here to establish identical test conditions. Actual detection depends on installation, target movement, settings and surroundings. Test the required route, and assess recorded detail separately from whether an alert was triggered.
What storage options does the aosu T2 Ultra have?
Storage depends on the selected camera and hub configuration. The current product pages distinguish microSD expansion for aosuBase 2.0 from hard-drive expansion for aosuCortex, but some specifications conflict. Confirm the hub model, compatible media and maximum capacity before purchasing. Compare the Base 2.0 package information and Cortex package information, then obtain model-specific confirmation where the listings disagree.
Does the aosu T2 Ultra support ONVIF, RTSP, or NAS?
No. ONVIF, RTSP, and NAS are not supported.
