The aosu T2 Ultra is an 8MP solar PTZ camera that records 3840 x 2160 video at 15 fps. It combines TrueColor Night Vision and Covert Full-Color Mode with PIR and dual radar detection, a 9,200 mAh battery, and standalone or aosuBase storage.
The camera is designed for outdoor areas such as driveways, yards, entry routes, and garage approaches where one adjustable camera position can cover a defined area.
Technical Specifications
| Imaging and coverage | Night vision and detection | Power and environment | Connection, storage, and recording |
Key Features
The T2 Ultra's camera, detection, and storage functions are designed to work as one outdoor monitoring system. The following features have the greatest effect on recorded detail, nighttime operation, alert behavior, and footage retention.
| TrueColor and Covert full-color modes | 4K PTZ imaging | PIR and radar detection | Standalone and aosuBase storage |
Storage options depend on the configuration: standalone cameras use microSD storage and can use optional cloud storage, while aosuBase bundles add built-in eMMC and external HDD or SSD support.
TrueColor Night Vision uses light to provide vivid full-color footage in complete darkness while balancing color richness and video smoothness.
Covert Full-Color Mode keeps footage in full color without turning on a spotlight and helps avoid the shadowy edges that spotlight illumination can create; video smoothness may be slightly reduced.
Compare the T2 Ultra with the T2 Pro
Usage and Installation Considerations
Camera placement determines how effectively the PTZ system, detection sensors, solar panel, and wireless connection operate together. Review the live view and test normal activity at the site before completing the installation.
| Mounting position | Solar-panel placement | Detection setup | Connection and audio |
The 3 W solar panel can be attached to the camera or mounted separately when the camera position and the best sunlight location differ. Separate placement uses the listed 3 meter cable.
How to reduce false motion alerts
View the aosu T2 Ultra product page
Summary
The aosu T2 Ultra combines 4K PTZ video, TrueColor Night Vision, Covert Full-Color Mode, PIR and dual radar detection, solar power, and multiple storage configurations in one outdoor camera system.
Its installation works best when the main activity route stays within the detection and night-vision ranges, the PTZ view remains clear of nearby obstructions, the solar panel receives suitable light, and the 2.4 GHz connection is stable at the mounting point.
FAQs About T2 Ultra Specifications and Features
What resolution does the aosu T2 Ultra record?
The T2 Ultra uses an 8MP PTZ camera and records at 3840 x 2160 resolution and 15 fps.
What is the difference between TrueColor Night Vision and Covert Full-Color Mode?
TrueColor Night Vision turns on the light and usually captures higher clarity in the center of the image. Covert Full-Color Mode records in color without turning on a spotlight and helps avoid the shadowy edges that spotlight illumination can create, although video smoothness may be slightly reduced.
What is the T2 Ultra motion-detection range?
The T2 Ultra lists 10 m PIR detection with dual 10 m radar detection and 60 GHz mmWave radar.
What storage options does the aosu T2 Ultra have?
A standalone camera supports microSD storage and optional cloud storage. aosuBase bundles add built-in 32 GB eMMC storage and support for an external 2.5-inch HDD or SSD.
Does the aosu T2 Ultra support ONVIF, RTSP, or NAS?
No. ONVIF, RTSP, and NAS are not supported.
