Security cameras are a major deterrent, but they still need to be set up with tampering in mind. A determined burglar can try to damage a camera, steal it, cover the lens, cut power, interrupt Wi-Fi, or interfere with a wireless signal.
That does not mean cameras are easy to beat. The goal is to set them up so they record the approach, send alerts quickly, keep footage somewhere protected, and keep watching even if one camera is lost.
A layered setup can reduce the impact of tampering, but footage survives only if it is successfully recorded and remains accessible. Check the recording path as carefully as the camera position.
Start Here
Yes, burglars can disable security cameras in some situations. The most common risks are physical tampering, camera theft, power loss, internet outages, and wireless interference.
| Higher risk setup | Better protected setup |
How Burglars Can Try to Disable Security Cameras
Most camera tampering is simple. A person may try to avoid the camera, cover it, knock it out of position, damage it, or remove it from the wall. Wireless cameras can also be affected by internet outages or signal interference.
Here are the main risks to plan around without getting lost in worst-case scenarios.
Physical damage or theft
A camera mounted within reach is easier to grab, twist, cover, or break. This is why placement matters as much as camera quality.
Blocking the lens
A camera does not have to be removed to lose its view. Someone can cover the lens, spray it, shine a bright light toward it, or move it away from the important area.
Power interruption
Wired cameras can stop recording if power is cut and there is no backup. Battery and solar cameras reduce that risk, but the router or storage device may still need power.
Wi-Fi or internet disruption
Some wireless cameras need Wi-Fi for live view, alerts, cloud upload, or remote playback. If the internet goes down, local recording may continue on some systems, but app access can be limited.
Wireless signal interference
Wireless interference can interrupt the camera-to-router or camera-to-hub connection. Moving a hub indoors protects it from easy physical access, but does not protect the wireless transmission itself. If that connection fails, new footage may not reach the hub.
Recording during the interruption requires a supported alternative, such as camera-side storage configured to record without that link. Do not assume that a camera buffers missing clips or uploads them later. Verify those functions for the exact camera, hub and firmware.
Exposed recorders or storage hubs
If footage is stored on a visible recorder, hub, or SD card that can be taken quickly, the camera may record the event but lose the evidence. Storage needs protection too.
How to Make Cameras Harder to Disable
You do not need a complicated setup to make camera tampering much less effective. The biggest improvements usually come from where the cameras are placed and where the footage is stored.
| Camera placement | System protection |
How to Protect Footage If a Camera Is Stolen or Damaged
The most important question is not only whether the camera survives. It is whether the recording survives.
Storing footage away from the camera can reduce the risk of losing it with the device. The important condition is that the clip must reach that storage and be successfully saved before the camera or connection fails.
Compare Storage Locations and Their Dependencies
| Storage location | What it can protect | What still needs checking |
| Cloud | Clips already uploaded can remain available after camera theft | Upload completion, internet access, account access and retention |
| Indoor hub or recorder | Clips already saved can remain separate from a stolen camera | Camera-to-recorder connection, recorder power, storage health and access after camera removal |
| Storage inside the camera | Supported models may record without a working external connection | Offline recording support, power and storage availability; theft may remove the recording too |
Two destinations are not necessarily two independent recording paths. If both depend on the same interrupted wireless link, neither may receive new footage. Confirm where recording happens first and what the system does when each connection fails.
For more context, read how security cameras store footage and what works without subscription fees.
What to Do If Someone Disables a Security Camera
If there is an immediate threat, prioritize personal safety and contact the appropriate emergency service. Once safe, preserve what remains before changing the system.
- Export available recordings. Check each camera and storage destination for the relevant period. Include footage before and after the event where available.
- Keep the original files. Retain the unedited downloads and existing recordings. Screenshots and phone recordings of playback are useful supplements, not replacements for the original video.
- Record context. Note the camera name, incident time, displayed timestamp, time zone and any known clock error. Save related notifications.
- Avoid destructive troubleshooting. Do not format storage, factory-reset or remove devices from the account before preserving evidence or obtaining guidance.
- Document and report. Photograph damage without unnecessarily disturbing the scene. Follow local police and insurer instructions.
Police.uk’s evidence-preservation guidance provides a UK example. If footage cannot be exported, record the displayed date and time and ask the relevant authority or manufacturer for assistance.
Build Layers That Address Different Failures
Use overlapping views to record the approach to a camera, protect the recorder from easy access, and confirm that useful clips reach storage. These measures address different risks, but they do not guarantee a recording of every incident.
Check shared dependencies. Two wireless cameras using the same hub may both lose their recording path during the same disruption. A cloud copy may also depend on that hub and internet connection.
Example coverage and recording paths. Overlapping views do not create an independent backup if both cameras rely on the same failed connection or recorder.
This diagram is a hypothetical arrangement, not a tested aosu configuration. The power symbols identify the shared hub and router supply in this example; camera power and any alternative recording support must be verified separately.
Before choosing a kit, ask where each camera records first, what happens when its local connection fails, and whether already-saved clips remain accessible after camera removal. Use the aosu support contact to request confirmation for the exact camera and hub combination.
Review the setup periodically. The goal is to reduce the impact of a failure and preserve available footage, rather than assume that adding another device makes the system independent.
FAQs About Burglars Disabling Security Cameras
Can burglars disable wireless security cameras?
Yes. Wireless cameras can be damaged, stolen, covered, knocked offline, or affected by Wi-Fi and internet problems. The best protection is strong placement, overlapping camera views, alerts, and footage stored away from the camera.
Can Wi-Fi jammers stop security cameras?
Wireless interference can interrupt live view, alerts or recording transfer over the affected link. A hidden indoor hub does not prevent that interruption. Recording may continue only where the exact model supports a functioning local or alternative recording path. Do not assume missing clips will be uploaded later.
Is cloud storage better if someone steals a camera?
Cloud storage can preserve footage that was successfully uploaded before the camera or connection failed. A hub can preserve footage already saved indoors. Neither location guarantees that the final moments were transferred. Compare upload behavior, storage retention and access after camera removal for the exact system.
Where should I put a camera so it is harder to disable?
Mount outdoor cameras high enough that they cannot be reached easily, aim them at approach paths, and use another camera to cover the route someone would take to reach them. Avoid placing the only camera low beside a door where it can be grabbed immediately.
What should I do if someone steals or damages my security camera?
Save app alerts, download any available clips, check cloud and local storage, document the camera location, and report the incident if needed. Afterward, improve the weak point by changing the mount location, adding another camera angle, or protecting the storage device.
