The best doorbell camera without a subscription lets you record, replay, and save video without a monthly plan. Our five picks cover simple battery installation, continuous recording, package coverage, expandable storage, and smart-home integration.
Best No-Subscription Doorbell Cameras at a Glance
Each pick supports local recording without a required monthly plan. Choose by power, storage location, and the view you need.
| Doorbell | Best for | Power | No-plan local storage | Useful included features |
| aosu Video Doorbell Pro | Simple battery setup with indoor storage | Rechargeable battery | microSD up to 128 GB in included aosuBase Mini | 2K video, human detection, snapshot alerts, smart playback |
| Reolink Video Doorbell WiFi | Wired 24/7 local recording | Existing doorbell wiring or included power adapter | microSD up to 256 GB; Home Hub, NVR, FTP, or NAS options | 5MP video, person/vehicle/animal detection, scheduled or continuous recording |
| eufy Video Doorbell E340 | Packages and built-in storage | Rechargeable battery or existing wiring | 8 GB built into the doorbell | 2K dual-camera view, package and human detection, color night vision |
| Tapo TD21 | Expandable in-camera storage | Rechargeable battery | microSD up to 512 GB inside the doorbell | 2K head-to-toe view, person detection, color night vision, quick replies |
| Aqara Doorbell Camera Hub G410 | Apple and advanced smart-home households | Six AA batteries or existing wiring | microSD up to 512 GB in the indoor chime; NAS backup supported | 2K video, local face recognition, broad ecosystem support, built-in smart-home hub |
Best Doorbell Cameras Without a Subscription by Use Case
aosu Video Doorbell Pro — Best for a Simple Battery Setup with Indoor Storage
The aosu Video Doorbell Pro makes battery installation practical while keeping recordings indoors. Its included aosuBase Mini stores event video on a microSD card up to 128 GB, so removing the outdoor doorbell doesn't take the saved footage with it. The card is sold separately.
The doorbell combines 2K video with human detection, snapshot notifications, and smart playback. It's a straightforward choice for a front door without existing wiring, with local event recording and an indoor base included.
· View the aosu Video Doorbell Pro
Reolink Video Doorbell WiFi — Best for Wired 24/7 Local Recording
Reolink's Video Doorbell WiFi stands out for continuous local recording. With power from suitable doorbell wiring or an adapter, it can save a full front-door timeline as well as motion-triggered or scheduled video.
The 5MP camera includes person, vehicle, and animal detection. Record to a microSD card up to 256 GB, or connect it to a compatible Home Hub, NVR, FTP server, or NAS for a larger system.
eufy Video Doorbell E340 — Best for Packages and Built-In Storage
The eufy E340 uses two cameras to show visitors and deliveries together: one faces the person at the door, while the other looks down toward packages. Its 2K video and color night vision make it a useful fit for a busy porch.
With 8 GB of storage built into the doorbell, local recording can start without a separate memory card or HomeBase. Human and package detection help identify arrivals, and an optional HomeBase can move storage into a centralized system.
Tapo TD21 — Best for Simple, Expandable In-Camera Storage
The Tapo TD21 keeps storage simple: a microSD card up to 512 GB fits directly into the battery-powered doorbell, without an indoor storage hub. The card is sold separately, and local event recording works without a Tapo Care plan.
Its 2K, 160-degree head-to-toe view helps show visitors and packages near the door. Person detection, activity zones, color night vision, two-way audio, and quick replies cover everyday front-door use.
Aqara Doorbell Camera Hub G410 — Best for Apple and Smart-Home Integration
The Aqara G410 combines a video doorbell with a smart-home hub. Apple Home support, local face recognition, a Matter controller, and a Thread border router make it a strong fit for households connecting several smart-home devices. It also supports Alexa, Google Home, and SmartThings.
Its 2K camera has a broad 175-degree view, while the indoor chime stores footage on a separately purchased microSD card up to 512 GB and supports NAS backup. The doorbell can run on six AA batteries or existing wiring; continuous recording requires wired power.
Where Should a No-Subscription Video Doorbell Store Footage?
A doorbell with built-in memory or a microSD slot keeps video in the outdoor unit. An indoor chime or base keeps recordings inside if the doorbell is removed. A compatible hub, NVR, or NAS offers more room for recording history and other cameras.
· Compare base station vs microSD card storage
· Compare cloud storage vs local storage
Before You Choose
1. Power and recording: Choose battery power for flexible placement and event clips, or a continuously powered model for 24/7 recording.
2. Storage and included hardware: Confirm where clips are saved and whether the package includes the card, chime, base, or recorder you need.
3. Features without a plan: Check that playback, downloads, and the alerts you want work without a subscription. Cloud backup and some advanced features remain optional paid services.
Choose aosu for a simple battery setup with indoor storage, Reolink for wired 24/7 recording, eufy for package views, Tapo for expandable in-camera storage, or Aqara for smart-home integration. Match the recording mode and storage location to your front door, then confirm the hardware included.
What is the best doorbell camera without a subscription?
The aosu Video Doorbell Pro is our best fit for a simple battery installation with footage stored on an included indoor base. Reolink Video Doorbell WiFi is better when you want wired 24/7 recording, while eufy E340 is stronger for package-focused dual-camera coverage.
Can a doorbell camera record without a monthly fee?
Yes. A local-storage video doorbell can save events to built-in memory, a microSD card, an indoor chime or base station, a hub, an NVR, or a NAS without a recurring storage plan. The required hardware varies by model.
Do no-subscription doorbell cameras work without Wi-Fi?
Not completely. Some models may continue recording locally during an internet outage, but remote live view, phone notifications, app playback, firmware updates, and two-way talk may be limited. Check the exact offline behavior for the model.
Is local storage safer than cloud storage for a video doorbell?
Local storage gives you more direct control and avoids a required cloud fee, but it can be lost with the doorbell or damaged with the home. Indoor base-station storage and optional off-site backup reduce different risks.
Can a battery doorbell camera record 24/7 without a subscription?
Usually not. Battery doorbells normally record motion events to preserve power. Conventional 24/7 recording generally requires continuous wired power and enough local storage, as with supported wired doorbell, hub, or NVR setups.
