This is one of those little details that might not come to mind until you’re ready to install, but it’s important to get it right. Installing at the wrong height can drastically reduce effectiveness of a security camera.
For most home security cameras, the ideal mounting height is between 7 and 10 feet above the ground. This height provides a good balance between visibility, security, and motion detection accuracy.
However, the best height can vary depending on where the camera is placed, what you want it to capture, and the camera type.
Why Security Camera Height Matters
1. Identifying Details
Cameras mounted too high will have a drastic top-down angle that may only capture the tops of people’s heads, which makes identification difficult.
2. Motion detection accuracy
Most modern cameras use motion sensors designed to work at specific angles, and mounting too high can cause motion detection to trigger less reliably.
3. Tamper protection
A camera mounted at eye level is easier for trespassers to cover, destroy, or take. Mounting the camera higher helps protect it from tampering.
4. Field of view
Higher mounting placement can give cameras a wider viewing angle, potentially allowing you to monitor a larger area with a single device.
Here’s an illustration comparing mounting heights with security camera POV
Recommended Security Camera Heights by Location
While 7–10 feet is generally the sweet spot, different parts of your home may require slightly different placement.
Front Porch Cameras
Recommended height: 7–9 feet
This placement allows the camera to capture faces clearly and see package deliveries while still avoiding easy tampering. Not to be confused with video doorbells
Video Doorbells
Recommended height: 4-5 feet
Video doorbells are meant to be installed at an easy-to-reach height so guests can ring the chime. This also allows for an extremely clear front view of visitors and strong package monitoring.
Garage or Driveway Cameras
Recommended height: 9–12 feet
Mounting cameras slightly higher in these areas helps capture the full view around your vehicles so that no theft or vandalism is hidden behind your car. Try to choose a camera designed for higher mounting positions so that motion detection remains effective.
Backyard Cameras
Recommended height: 8–11 feet
Backyard cameras often monitor large areas. Higher placement can help cover patios, fence lines, back gates, pools, and play areas. If you want to focus coverage on your back door specifically, then a lower height closer to the door is ideal.
Indoor Cameras
Recommended height: 5–8 feet
Indoor cameras don’t need to be mounted as high since tampering is less likely. Placing them on shelves or furniture can be an easy alternative to mounting while still providing effective coverage.
Common Security Camera Placement Mistakes
Mounting too high
Some homeowners mount cameras near the roof peak (15–20 feet). This often results in footage that doesn’t capture identifying details and negates the effectiveness of motion detection.
Mounting too low
Since most outdoor security cameras are designed for 7-10 feet, they are angled slightly downward. Mounting too low can result in cutting off the view of people’s faces.
Mounting near obstruction
Even at the right height, a nearby pillar, tree, or decoration can easily block a large part of the view and even interfere with auto-tracking. Try to avoid mounting next to large objects or bright lights.
Mounting too far away
Consider your connection method when mounting your security camera. Wired cameras will need a wire run to their location and Wi-Fi cameras will need to be in connectivity range. If you want a security camera on a distant outbuilding, you may want to consider a 4G camera.
Tips for Getting the Best Security Camera Coverage
To get the most reliable performance from your cameras:
- Mount most cameras between 7–10 feet
- Ensure cameras are angled to capture faces
- Choose the correct cameras for your security goals
- Avoid mounting near obstructions
- Test viewing angle and motion detection before drilling in the mount
The right mounting height can make a big difference in how effective your security cameras are. In most situations, installing cameras about 7–10 feet above the ground offers the best combination of visibility, motion detection, and security.
Proper placement and thoughtful setup can drastically increase the effectiveness of security cameras.
FAQs About Security Camera Mounting Height
Can I install a security camera lower than 8 feet?
Installing a security camera lower than recommended doesn’t render it useless. The main problems will be decreased coverage, decreased likelihood of faces being in camera view, and more prone to tampering.
Can I install a security camera higher than 10 feet?
Installing a camera too high will usually decrease face visibility, will often create a blind spot close to your home, and likely hinder the accuracy of motion detection. However, it will not render the camera useless.
Do I need a ladder to install a security camera?
Most outdoor security cameras will require a ladder to safely install at the correct height. However, a sturdy chair or other alternative could be used with caution.
