Airbnb camera rules are easy to misunderstand because the answer used to be more complicated. The old question was whether a camera was visible, disclosed, and outside a private space. The current answer is simpler.
Airbnb hosts cannot have indoor security cameras in listings. Outdoor cameras, doorbell cameras, and some noise monitors may still be allowed, but they need to follow disclosure and privacy rules.
Quick Answer: Can Airbnb Have Cameras?
Yes, an Airbnb can have cameras in limited places, but not inside the rental. Airbnb's current policy bans indoor security cameras in listings, even if the host discloses them.
Exterior cameras can be allowed when they are disclosed before booking and do not look into indoor spaces or private outdoor areas. A doorbell camera facing the entryway is very different from a camera inside a living room, bedroom, bathroom, or hallway.
| Generally allowed when disclosed: | Not allowed: |
Indoor Cameras Are Not Allowed in Airbnb Listings
The most important rule is the simplest one: Airbnb does not allow indoor security cameras in listings. That includes common areas, not just bedrooms and bathrooms.
This matters because some older advice still says indoor cameras may be allowed in shared spaces if they are disclosed. That was Airbnb's older approach. Airbnb changed its policy in 2024 and banned indoor cameras in listings regardless of location, purpose, or prior disclosure.
For guests, that means a disclosed camera inside the rental is still a problem. For hosts, it means the safe rule is easy: do not put cameras inside the Airbnb space.
Outdoor Cameras Can Be Allowed, But They Must Be Disclosed
Airbnb can allow exterior cameras and doorbell cameras when they are used in appropriate places and disclosed to guests before booking. A camera at the front door, driveway, side gate, or garage approach is usually the kind of setup hosts are trying to use for property security.
The camera still has limits. It should not monitor the inside of the rental, point through windows, or cover outdoor spaces where guests reasonably expect privacy. An enclosed outdoor shower, sauna, or similar private space is not the same as a driveway.
Good disclosure should tell guests where the camera is and what area it covers. A vague line like "security cameras on property" is less helpful than "doorbell camera facing the front entry" or "exterior camera covering the driveway."
Read the home security cameras guide
Noise Monitors Are Different From Cameras
Airbnb also treats noise decibel monitors differently from cameras. A decibel monitor is meant to measure sound level and duration, not record conversations.
That distinction matters. A device that records or transmits conversations is a privacy problem. A disclosed device that only measures whether sound levels are getting too high is generally used by hosts to prevent parties or noise complaints.
If you are a host, make sure the device does not record audio. If you are a guest, read the listing details so you know whether a noise monitor is present.
What Guests Should Check Before Booking
If you are booking an Airbnb and care about cameras, check the listing before you reserve. Look for disclosed exterior cameras, doorbell cameras, shared-building cameras, and noise monitors.
The goal is not to panic about every camera. It is to understand what is outside for security and what would cross the line into private-space monitoring.
- Read the safety and amenities details
Look for camera, recording device, doorbell camera, and noise monitor disclosures before booking.
- Check where the camera points
A front entry camera is different from a camera aimed at a patio, pool, hot tub, or window.
- Ask before booking if wording is vague
If a listing says cameras are on the property but does not say where, ask the host for the exact location and view.
- Treat indoor cameras as a serious issue
If you see a camera inside the rental, contact Airbnb support and document what you found.
What Hosts Should Do Before Installing a Camera
For hosts, the cleanest approach is to keep cameras outside, disclose them clearly, and make sure they only cover legitimate security areas.
Local law may be stricter than Airbnb policy, especially around audio recording, consent, shared spaces, and tenant privacy. Airbnb compliance is not the same thing as legal compliance.
| Good host practice | Avoid |
What to Do If You Find a Camera in an Airbnb
If you find a camera indoors or an undisclosed camera in a place that feels private, take it seriously. Start by documenting what you found with photos or video, including where the device is located and what direction it appears to face.
Contact Airbnb support through the app or website. If you feel unsafe or believe someone is actively recording you in a private space, leave the area and consider contacting local authorities.
Avoid destroying or taking the device unless there is an immediate safety reason. Documentation is usually more useful than a confrontation, especially if Airbnb or law enforcement needs to review the situation.
Read how security cameras record without Wi-Fi
Do not assume a disclosed indoor camera is allowed. Airbnb's current policy bans indoor security cameras in listings.
Do not assume every outdoor camera is a violation. A properly disclosed entry camera can be allowed when it is not pointed at private areas.
Do not ignore audio. Audio recording can raise separate privacy and legal issues, even when video placement seems reasonable.
Do not rely only on Airbnb policy. Local law, building rules, lease terms, or HOA rules can add stricter limits.
Do not use vague disclosure if you are a host. Say where the camera is and what area it covers.
Airbnb can have cameras, but only within tight limits. Indoor cameras are not allowed in Airbnb listings. Outdoor cameras and doorbell cameras may be allowed when they are disclosed and placed where guests do not have a strong expectation of privacy.
For guests, the practical move is to check the listing and report anything that feels hidden, indoor, or aimed at a private space. For hosts, the practical move is to keep cameras outside, disclose them clearly, and check local law before relying on any recording device.
Can Airbnb hosts have cameras inside?
No. Airbnb's current policy does not allow indoor security cameras inside listings, even if the host discloses them.
Can Airbnb have outdoor cameras?
Yes, outdoor cameras can be allowed when they are disclosed before booking and do not monitor indoor spaces or private outdoor areas.
Are hidden cameras allowed in Airbnb rentals?
No. Hidden cameras are not allowed. Guests who find a hidden or undisclosed camera should document it and contact Airbnb support.
Can an Airbnb have a doorbell camera?
Yes, a doorbell camera can be allowed when it is disclosed and aimed at an appropriate exterior area such as the entryway.
Are noise monitors allowed in Airbnb rentals?
Noise decibel monitors can be allowed when disclosed, but they should measure sound levels rather than record conversations.
