How to Tell If a Security Camera Is On and Recording
A camera can look installed and still be offline, disconnected, or not recording. This guide walks through simple checks that help you confirm if your CCTV or security camera is actually working.
To tell if a security camera is on, open the app, hub, DVR, or NVR you are authorized to use and confirm that the live image is current. To confirm that it is recording, create a simple test event and play the new clip or timeline segment.
A status light, infrared glow, or moving lens can show that part of the camera is active, but none proves that usable footage is being saved. A camera can have power without a connection, show live video without recording, or continue recording locally while remote access is offline.
The checks below work for CCTV systems, app-based security cameras, video doorbells, home hubs, NVRs, DVRs, and cameras with a microSD card. Use them for equipment you own, manage, or have permission to inspect.
How to Tell If a Security Camera Is On: The Short Answer
Open live view and confirm that the image changes when someone moves through the frame. That shows the camera is powered and connected at that moment.
Next, walk through the normal detection area, wait for the event to finish, and open playback. Find the new footage under the correct camera and check its timestamp. A clip you can play is the clearest confirmation that recording works.
If live view works but no new recording appears, check the recording mode, schedule, detection settings, and storage status.
Decision chart for checking whether a security camera is powered, connected, and recording
The strongest check is not a single light. Confirm power, connection, and a recent saved event.
Quick Check for an aosu Camera
In the aosu app, open the camera from the Devices page and confirm that the live image is current. Then walk through the normal detection area, wait for the event to finish, and open Events under that camera.
Play the newest event and check its timestamp. If the camera uses local storage, confirm that you are viewing the correct local recording source. If it uses aosuProtect+, confirm that the event was uploaded to the cloud library.
A working live view confirms that the camera is reachable at that moment. A playable event confirms that a recording was saved. You need both checks to know that the system is operating as expected.
Learn more by: https://community.aosulife.com/t/app-manual/213
https://www.aosulife.com/pages/cloud-storage
Before You Start: Know What You Are Checking
"On" can refer to four separate states. Check each one so a working live view is not mistaken for a working recording system.
Powered on
  • The camera has electricity or battery charge
  • Status lights, app device info, or power supply may confirm this
  • A powered camera is not always online or recording
Online or connected
  • The camera can talk to the app, hub, Wi-Fi router, NVR, or recorder
  • Live view is usually the easiest confirmation
  • A connected camera may still have recording turned off
Recording
  • The system is saving footage, clips, or event history
  • Playback timeline, SD card files, NVR footage, or cloud clips can confirm it
  • Recording mode may be motion-based rather than continuous
Detecting events
  • Motion detection, zones, schedules, and alerts are active
  • A test walk-through can confirm whether the camera notices activity
  • Low sensitivity or disabled zones can make a working camera miss events
Choose the Check for Your Camera Type
Setup First check Recording proof Storage to inspect
aosu battery or solar camera Open live view or check the device status in the aosu app Trigger motion and play the new event microSD, aosuBase, aosuCortex or aosuProtect+, depending on the exact setup
aosu plug-in camera Open live view Play a new event or continuous timeline segment Usually microSD or supported cloud event storage
aosuBase kit Confirm the camera and base appear online Open Events and play the new locally stored event Included or added base storage
aosuCortex system Confirm the camera and Cortex are connected Play the new event from the correct camera Cortex internal or supported expanded storage
Traditional DVR/NVR system Check the correct recorder channel Play the new timeline segment DVR or NVR hard drive
The exact bundle matters. An aosu camera sold by itself may use a microSD card, while a kit may store recordings on aosuBase or aosuCortex. Live view can work even when no active recording destination is available. (Know more by: local storage aosubase and aosucortex explained)
6 Ways to Tell If a Security Camera Is On
Combine the checks. A light can indicate power, a current live view confirms connection, and a new playable clip confirms recording.
Check the Status Light—If Your Model Uses One
A status light can indicate power, pairing or network status, but its meaning is model-specific. Do not apply one camera’s LED colors to another model, and remember that some cameras allow the status light to be disabled.
For example, aosu’s indoor-camera guide describes a short steady green light as power-on, blinking green as waiting for network configuration, blinking blue as offline and steady blue as online. Those meanings apply to the models covered by that guide; check the manual for your exact camera before interpreting its light.
A light still does not prove that video is being saved. Confirm recording by playing a recent event or timeline segment.
Open Live View in the App or Recorder
Load live video and confirm that the image changes when someone moves through the frame. For an aosu camera, open the correct device from the Devices page in the aosu app.
A current live image confirms that the camera is powered, connected and reachable at that moment. It does not prove that motion detection, local storage or cloud event recording is working.
If the image does not load, check the camera’s power or battery, its Wi-Fi or base connection, and whether the device is shown as offline. For a DVR or NVR system, check the correct recorder channel and cable connection instead.
Play a Recent Recording
For an aosu camera, tap Events under the correct device and play the newest recording. Check the camera name, timestamp and view. If the setup uses a microSD card, switch to the local recording view where the app provides that option.
A thumbnail or notification is not enough. Play the video itself and confirm that it contains the expected movement. If you need to preserve the test, download the event and open the saved file on your phone.
For another camera brand or a CCTV recorder, use its timeline, event list, DVR, NVR or cloud library.
Create and Verify a Test Event
Walk through the camera’s normal detection area for several seconds, then leave the view and wait for the event to finish. Open Events, find the new recording and confirm that its timestamp and camera view match your test.
If you receive an alert but no playable recording appears, check the configured storage path, recording mode, motion zone, sensitivity and schedule. An alert proves that detection occurred; it does not prove that the video was saved.
Repeat the test at night if that is when the problem occurs. Battery cameras may wake from a low-power state only after motion is detected, so allow enough time for the event to finish before checking playback.
Check the Camera, Network and Storage Device Separately
Check whether the camera appears online in the aosu app. If the setup uses aosuBase or aosuCortex, confirm that the hub is also powered and connected. A camera, hub and storage device are separate failure points.
For a standalone camera, confirm that the required microSD card is installed and recognized. For a wired CCTV system, check the relevant NVR or DVR channel, Ethernet cable, PoE connection and recorder drive.
Do not assume that a working internet connection proves local recording is working, or that a working SD card proves remote access is available.
Check Night Mode, Then Verify the Recording
Some cameras show infrared LEDs or switch to a night image in darkness. That indicates that part of the camera is active, but it does not confirm that the camera detected activity or saved footage.
Walk through the detection area after dark, then play the resulting event. Check whether the person is visible, whether the timestamp is correct and whether the complete test was recorded.
Infrared LEDs may be difficult to see or may be hidden, and some cameras use a spotlight or color night vision instead. Do not use visible red light as the only test.
Illustration showing a camera status light, app live view, and recent recording timeline checks
Why "On" Does Not Always Mean Recording
A camera can be powered and online without saving every moment. Many home security cameras record only when motion is detected. Some record on a schedule. Others record continuously to an NVR, home hub, microSD card, or cloud service.
Check the recording mode, schedule, detection settings, storage status, and any privacy or sleep mode. Live streaming and recording are separate functions: a current image shows that the camera is reachable, while playback shows that stored footage exists.
If you recently changed storage, a subscription, Wi-Fi, or a recording schedule, run the test event again afterward.
• Learn how security cameras store footage
What to Check If the Camera Looks Off or Offline
If the camera does not show live view or recent recordings, start with the simplest causes before replacing anything.
An internet outage can stop remote live view, app alerts and cloud uploads while some local recording systems continue saving footage. For aosu cameras using supported microSD recording, official support guidance states that local recording can continue while the camera is offline and become available after the camera reconnects.
Do not assume the same behavior for every aosuBase or aosuCortex combination without checking the exact model documentation. Cloud recordings cannot be uploaded while the camera is offline, and footage saved to the SD card during the outage is not automatically uploaded to the cloud later.
1. Power source: Check the outlet, power adapter, PoE cable, battery level, solar panel connection, or charging cable.
2. Internet or local network: Restart the router if other devices are also having issues. For wired systems, check the Ethernet cable, PoE switch, and NVR channel.
3. App, hub, or recorder status: Confirm whether the device appears online in the app, home hub, NVR, or camera management screen.
4. Storage problem: Check whether the SD card, home hub, NVR drive, or cloud storage is full, disconnected, corrupted, expired, or disabled.
5. Privacy, notification and recording settings: Check Privacy Mode, recording schedules, detection schedules and notification settings separately. On supported aosu indoor cameras, Privacy Mode can intentionally stop monitoring. By contrast, the aosu app’s Snooze setting stops notifications for the selected period but continues recording.
Special Notes for Battery and Solar Cameras
Battery cameras can behave differently from wired CCTV cameras. Many battery models remain in a low-power state until motion wakes them, so an idle camera can still be operating normally.
Check the battery level, solar charging status, motion sensitivity, activity zones, clip length, event interval, and schedule. Then walk through the detection area and confirm that a new event appears in playback.
For aosu cameras, check live view, device status, battery level, and the Events history. Use the device page and model manual for the exact status-light and recording options.
How to optimize security camera battery life
If the aosu Test Still Fails
Before contacting support, collect:
  • the camera model and bundle name;
  • the serial number shown in the app;
  • the app and firmware versions;
  • whether the camera appears online;
  • the configured storage path;
  • the time of the failed test;
  • a screenshot of the device status or storage error;
  • whether live view, alerts and playback each worked.
In the aosu app, use Online Support from the bottom navigation. You can also contact aosu through its support page. Do not format the SD card or delete the device before preserving any accessible recordings and screenshots.
What If It Is Not Your Camera?
Visible lights, lens movement, or infrared emitters can show that some hardware is active, but they cannot tell you whether someone else's camera is saving footage. Do not touch, block, unplug, damage, or try to access a camera you do not own or manage.
For a workplace, store, apartment building, or managed property, ask the responsible manager about its camera policy. For a neighbor-camera concern, document the placement from your own property and focus on the privacy issue rather than trying to infer recording status from a light.
• Read the guide to neighbor security camera privacy
1. Trusting the status light alone: A light is only a clue. Confirm with live view, playback, or event history.
2. Assuming live view means footage is saved: Live view confirms connection, but recording can still be disabled or limited by storage, schedule, or plan settings.
3. Forgetting motion zones and schedules: A camera may miss activity if the motion zone excludes the area you are testing or if recording is scheduled for another time.
4. Ignoring storage warnings: A full, failed, unformatted, or missing storage device can stop recordings even when the camera itself works.
5. Testing only once: If the issue happens at night, during bad Wi-Fi periods, or after battery drain, test under those conditions too.
To tell if a security camera is on, confirm a current live view through the authorized app, hub, DVR, or NVR. To tell if it is recording, create a test event and play the new footage from the correct local or cloud storage source.
If the test fails, the point where it stops tells you what to check next: power, connection, detection settings, storage, or the recording schedule.
How can you tell if a security camera is on?
Open the authorized app, DVR, NVR, or home hub and confirm that the selected camera shows a current, changing live image. A status light can support the check, but its meaning depends on the model and the light may be disabled.
Does a red light mean a security camera is recording?
Not by itself. A red light can indicate night vision, power, charging, recording, or an error depending on the camera. Check the model manual, then confirm recording by playing a recent saved clip.
Can a security camera be on without recording?
Yes. It can have power and show live video while recording is disabled, outside its schedule, blocked by a storage problem, or waiting for a motion event.
How can I test whether my security camera is recording?
Walk through the normal detection area, wait for the event to finish, and open playback. Confirm that the new footage has the correct camera name, timestamp, and view of your test.
Can an aosu Camera Record While It Is Offline?
An aosu camera using supported microSD local recording can continue saving video while offline, according to aosu support guidance. The footage becomes available after the camera reconnects. Cloud uploading pauses during the outage, and the locally saved footage is not automatically copied to the cloud afterward. Check the exact model if your recordings are stored on aosuBase or aosuCortex instead of a card.
